Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This has been the MOST helpful forum that I have been a part of and I want to say thank you. The tips, tricks and helpful advice that you all contribute to have been lifesavers in many instances..."
Geography
No cutting head in bystronic byspeed when one is present
tazzmania (Industrial)
8 Mar 12 9:01
good day
i have a bystronic byspeed 3015 4,4 kw laser
we have a problem on the machine that both cutting heads when in and you want to calibrate the cutting heads it comes up with an error message that it say no cutting head available .
did any one ever experiance this problem and what did you do to rectify it
please help
krugtech (Industrial)
10 Mar 12 12:15
from what I understand, with the original byspeeds, it was possible to open the shutter with no cutting head installed. The raw beam shooting directly into the nozzle holder is not good and it happened. A switch was supposedly fitted to the machines to prevent this, I would remove the head and look for this switch. They probably wired it into an input in the CNC cabinet.
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
delerium (Computer)
19 May 12 21:44
I have 4 bystronic machine. I had a same problem. check at ceramic nozzle and diode holder. change ceramic nozzle.
problem will be resolve.
Close Box
Join Eng-Tips® Today!
Join Us             Close
