Macro to populate custom properties
Hi all,
I have a macro to populate custom properties of SW file.
There are two things I need to be added and was hoping someone could help me (my VBA knoledge is very low).
1) Remove all exsisting custom properties
2) Get the filename so that Material and Weight are properley set.
"SW-Material@Part1.SLDPRT"
CODE
Sub main()
Set swApp = CreateObject("SldWorks.Application")
Set Part = swApp.ActiveDoc
Dim MyProp(1, 20) As String
'Property names
MyProp(0, 0) = "PartNo"
MyProp(0, 1) = "Title"
MyProp(0, 2) = "Production"
MyProp(0, 3) = "Description"
MyProp(0, 4) = "Remarks"
MyProp(0, 5) = "CheckedBy"
MyProp(0, 6) = "CheckDate"
MyProp(0, 7) = "Amount"
MyProp(0, 8) = "L"
MyProp(0, 9) = "W / d"
MyProp(0, 10) = "H / t"
MyProp(0, 11) = "Prop1"
MyProp(0, 12) = "Prop2"
MyProp(0, 13) = "Prop3"
MyProp(0, 14) = "Below should not be edited"
MyProp(0, 15) = "Revision"
MyProp(0, 16) = "Author"
MyProp(0, 17) = "Mass"
MyProp(0, 18) = "Material"
MyProp(0, 19) = "Project"
MyProp(0, 20) = "Number"
'Property values
MyProp(1, 0) = "[C1_00_00_00]"
MyProp(1, 14) = "Below should not be edited"
MyProp(1, 17) = "SW-Mass@Part1.SLDPRT"
MyProp(1, 18) = "SW-Material@Part1.SLDPRT"
Dim m As Integer
For m = 0 To 20
retval = Part.AddCustomInfo3("", MyProp(0, m), 30, _
MyProp(1, m))
Next m
End Sub
'Property names
MyProp(0, 8) = "L"
'Property values
Dim m As Integer
For m = 0 To 20
MyProp(1, m))
Next m
End Sub
RE: Macro to populate custom properties
Feel free to scalp some script.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
