Using Figure 6-17 of ASCE 7-05 (Components and Cladding)
I am bit confused using this kind of graph. Can someone help me to figure this out how to get the value of External pressure coefficient for windward, leeward and side wall..thanks in advance.
RE: Using Figure 6-17 of ASCE 7-05 (Components and Cladding)
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
It has lots of solved examples and very cheap investment.
Lutfi
Of course I am aware mike, I only asked how to obtain the coefficient for the external pressures. I do some calculations for mwfrs only and not for the components and cladding. So I am new with this thing. Thank you anyway.
To Lufti
Thank you for the suggestion, appreciate that. But I don't have to spend money for my simple problem if someone like DST148 is there to give help to those who are in need.
To DST148
Thank you so much for answering directly to my problem and I really appreciate your help, actually that is the only thing I need to know. Keep it up...God Bless..
You can use formula to replace the chart if you want to use it in Excel spreadshhet, see attached sample.
anchor bolt design crane beam design
http://www.civilbay.com
