3D x,y,z data import
Is it possible to import a 3D point "cloud" into solidworks? I initially want to only be able to visualize the data, but I would eventually like to be able to fit surfaces to the points and then ultimately build solids using those surfaces.
Anybody have any ideas?
Steve
Steve
RE: 3D x,y,z data import
I developed a macro that do this kind of thing. But this API tool isn´t generic, it works just with some kind of digitalized files. I developed it for a SW Client, once I work for a SW reseller.
Just to help you... could you send me the digitalized file??
I hope it can helps.
MHendler
Send me your email address and I will send you a file. I have a few different purposes for needing this capability. One is for visualization only. The more complex one is for taking a point cloud and fitting a surface to it.
Stoker, I checked out ShapeWorks and while it looks quite cool, they say the capability to import "cloud of points" data is "coming soon"!!!
Steve
Point Cloud from File - This macro/script reads in a table of xyz points from a space, tab, or comma delimited txt file and plots the points into one 3D sketch. It could also be used to create a 3D spline.
Note, access to this requires subscription support.
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
