Controlling the Position of Nodes in a Mesh
I have defined keypoints on a surface of my model. I would like to control the mesh so that it has a node at each of these keypoints. I am using ANSYS Mechanical APDL.
Any help would be much appreciated.
1cfc1
RE: Controlling the Position of Nodes in a Mesh
Create the surface using the keypoints created and mesh the surface. ANSYS will retain the positions of the keypoints as points on the surface and create nodes there.
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
you can create a node everywhere in your model (line, volume or area) using hardpoint. its command in mechanical apdl is hptcreate.
HPTCREATE, AREA,(area number), (number assigned to the hard point), COORD, (x coordinate of the point), (y coordinate of the point, (z coordinate of the point
http://www.narmafzar24.ir
Engineering Softwares Company
