trailing zeros in text anotation with expressions
Hello Community,
I am trying to create a text anotation to dimension a chamfer. I am using a relation to show the chamfer parameters/expressions in the text box.I encounter two problems(ref. to the attached image).
1)I am getting two zeros after the floating point and
2)I want to change the leader as it is shown on the image.
The white fraction of the image is what it should be, the greyed one is illustrating point 1) and 2)
Please, advise.
Greetings
Tish
RE: trailing zeros in text anotation with expressions
What version of NX are you using?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
Ahhh poor me :).
NX6.0.0.24
Greets
Tish
Have you tried to just create a Chamfer Dimension straight-away?
Shown below is how you shouls the Annotation Preferences before you create the Chamger dimension:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Wonderful. It worked as you said John. Thank you.
I didn't try to create the chamfer because I couldn't find it. I recently moved from CATIA to NX and the interface is pretty new for me. I wonder how I have under seen this tool and went that far with the text/expression options.
Greetings
Tish
BTW, I didn't mention this before, but on that same dialog shown above, the entry box labeled 'Space' controls the relative size of the 'gap' between the numbers and the 'X'.  Also note that in later versions of NX you have control over whether the 'X' is upper or lower case as well.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Good to know either. Thumb's up!
Greetings
Tish
Why allow an option that violates the standard? ASME Y14.5 shows that the 'X' used for repetitive dimensions is upper case. Also. all lettering on the face of a drawing (unless an accepted abreviation or standard nomenclature) should be in upper case per ASME Y14.2.
Looking at the original JPEG, the OP used the lower case option for the 'x'.
Ben Loosli
