induction motor performance
Three-phase induction motors are being supplied by an OPEN Y-DELTA transformer bank, i.e., there are only two primary phases.
If one of the primary phases opens, what is the effect on the motors ?
RE: induction motor performance
Gunnar Englund
www.gke.org
Or do you mean a V connection?
Gunnar Englund
www.gke.org
If you lose one phase the other phase will still provide full voltage and any running motors will be singled phased.
Bill
"Why not the best?"
Jimmy Carter
Gunnar Englund
www.gke.org
The first transformer on A phase is connected as a single phase distribution transformer which in North America has the secondary center tap/neutral grounded. This gives us A phase from L1 and L2. Two more transformers are connected to B phase. One of these transformers is connected to the neutral point to provide B phase. The third transformer is connected to L3 of the first transformer in such a direction as to produce C phase.
Typical transformer sizes may be 50 KVA, 25 KVA and 25 KVA.
Bill
"Why not the best?"
Jimmy Carter
Have a look at a Scott connected transformer. I can't claim to have invented it, but sounds similar to what you describe.
B
A _____/_____ D
N /
C
A-D is one transformer. (It may be two transformers if there is enough space on the pole to mount four transformers.)
N-B is the second transformer.
D-C is the third transformer.
Voltage drops on the primary neutral may contribute to voltage unbalances.
An open delta (or "V" connection on your side of the pond) is used to develop C phase.
I first learned of this connection on Eng-Tips. I think that I remember that a poster was having some voltage balance issues that were probably related to voltage drop in the primary neutral conductor.
Bill
"Why not the best?"
Jimmy Carter
