AC Condenser Pad Design Tips
Hello All,
I have used Eng-Tips throughout my college career, but this is my first time posting a thread.
I am designing a concrete AC condenser pad.  The pad will likely be 42" x 42" x 4" and will contain a foam core to reduce the overall weight.  The current target weight is 265 lbs, which is driven by the Florida Hurricane requirements.
I am wondering what basic design features I can incorporate to reduce the risk of cracking.  I'd like to keep the cost as low as possible, so I am trying to avoid re-bar.  I'm looking more for tips on the shape / geometry of the foam, wall thicknesses of the concrete, etc.
RE: AC Condenser Pad Design Tips
YEP!!
Agree with bimr and Mike...if you must have a concrete slab, look in the Florida Building Code....it gives a prescriptive method.
Don't worry about cracking....your slab is small, so shrinkage cracks, assuming a thickness of 4 inches, shouldn't be an issue.
I would thicken the edges to reduce scour/undermining potential.
Check your design vs these guys. They post excel spreadsheets for exactly what you're proposing.
http://www.diversitech.com/
