Is it possible to change middle + right button ?
Middle + Right Button launch Pan Operation, but I would like that this action launch Rotate Operation like in CATIA.
Is it possible ?
Thanks in advance
Didier Psaltopoulos
http://www.psi-cad.com
RE: Is it possible to change middle + right button ?
Thanks Jerry,
But this thread doesn't help me. Personnaly I use a space navigator, so I don't need to change the middle+right button.
But my customer doesn't want to buy a spaceball and during the day he uses Catia and sometimes NX. So it's very confusing for him.
I have a look at my mouse driver and it's possible to change one button action but no way to change two button action.
Any idea
TIA
Didier Psaltopoulos
Keep in mind that there's an alternative solution to this issue: simply ask the Catia-users if there's a way to configure the mouse buttons in Catia so that they are the same as NX.  Problem solved winky smile
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
Agree to Johns proposal smile
 But also, I assume that if measured, people rotate the view far more frequently than they pan the view ?! - and then the most frequent action should have the simpler shortcut which is the single button option instead of two buttons. ( Note that middle button Pans in Drafting)
 Tomas
Option 3 or 4 - buy a Space Explorer. Seriously, you'll never go back!
JHTH
NX 7.5.5 + TC 8.3.2.2
Hi everybody,
I agree with you because I use a Space Pilot Pro since many months and I will never go back.
I was looking for a workaround
Now, I have to persuade my customer !!!
Didier Psaltopoulos
