Submersible pump
Submersible pump
I want to provide one submersible pump to dewater the basement floor of a switch gear building ( max 6 mtr deep ) in case of any water accumalation.
Can any body give the spec
RE: Submersible pump
Probably a 1,000 vendors out there that can help you out
"Sharing knowledge is the way to immortality"
His Holiness the Dalai Lama.
http://waterhammer.hopout.com.au/
You'll need at least 6m head, call it 10.
You know what voltage you're operating with, we don't.
You probably want it to have float switches to turn it on and off.
I recommend putting a small sump hole at the low point to put the pump in, otherwise, if it's on the floor, you need one that pumps down to the lowest level possible.
Armed with that information, contact someone in your area who sells submersible pumps.
