Assembly EXPORT to customer
Magic button time
or a slick process required
I have an assembly of NX parts and have a requirement to export the external detail ONLY to a customer using a altenate CAD package [non parasolid based] (I am happy to consider STEP). I would also like to not show the internal detail. and to add more of a challenge solids would be nice, rather than a shell. I am sure this is not a crazy request and that someone out there has passed this way before. I am using NX7.5.3.3 MP1 but am a little new to some functionality and maybe missing a trick.
help would be appreciated
Gary
aerospace
Gary
aerospace
RE: Assembly EXPORT to customer
Ben Loosli
The STEP file will only have the shape, no construction details.
Ben Loosli
thanks for your thoughts
gary
www.nxjournaling.com
Assemblies -> Advanced -> Simplify Assembly...
However, if yor're only looking for a conservative 'armature' to be used for space planning or 'packaging' then...
Assemblies -> Advanced -> Wrap Assembly...
...may be something you may wish to look at since it's very quick and easy to use.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Ben Loosli
It's the 'Linked Exterior' which produces a series of sheet bodies which may or may not be easily 'sewen' into a final solid.
John R. Baker, P.E.
Industry Sector
Cypress, CA
thanks for the inputs ... i have taken a look at
and that is exactly what i need . sufficient automation on the complex parts with some level of control on extactly what i ship.
thanks to all for your help.
I am all set for now
best regards ... gary
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Any idea when 8.0.3.3 will be released?
The MR will be NX 8.0.3.4
As for when it will be released, it should out by the end of summer.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
