Analysis for Impact vs Constant Force?
I know how to analyze a structural system for a constant applied force, but what about impact forces? Are there some general tips or rules for what a structure might be able to handle in impact when it has been rated for a constant load? i.e. If a structure is rated to withstand a constant 5kN, can we estimate what sort of impact forces it would also withstand?
Thanks in advance!
Thanks in advance!
RE: Analysis for Impact vs Constant Force?
Check your mechanics of materials textbook under Strain Energy. This is where I was taught about impact loads.
Under impact, your structure must absorb the kinetic energy, somehow.
Cockroach
Thus, you personally could survive a 200-g impact if it was sufficiently short, but a long duration impact would squash you flat. The difference is the time integral of the force, which is correlated with the total energy of the impact.
TTFN
In the structure, TetWin11 would need to perform other basic calculations, of which we have no information. His general question got him a general answer. We have no idea of the collision, elastic or inelastic, material composition of bodies, deformation as a result thereof, impulse parameters, nothing. If the impact load was something on the order of 30 lbf in TetWin11 world, I would be considering his structure to statically withstand 90 lbf.
There would be other considerations of course. Just keeping it simple!
Cockroach
It isn't actually a rule of thumb, it is a perfectly good piece of physics for a single degree of freedom system... that lazy engineers have misused.
Cheers
Greg Locock
Tobalcane
"If you avoid failure, you also avoid success."
"Luck is where preparation meets opportunity"
Ted
Is that right?
Charlie
www.facsco.com
Now I need a new TV
Charlie
www.facsco.com
Ted
Cheers
Greg Locock
