Pro Batch DWG and PDF
Has anyone managed to Batch output either PDF or DWG files?
I've tried outputting .plt files from probacth, but alas, Acrobat Distiller doesn't like them for some reason.
I can't find any way to output .dwg files from probatch either.
These would be 2 really nice things to be able to do.
Thanks in advance,
Hayden
RE: Pro Batch DWG and PDF
Just use the print command and choose the acrobat distiller there (MS-Printermanager - Acrobat Distiller). You will get excellent quality.
The only disadvantage is the manually input of the paper format by defining width and height.
