Que concerning accelerometer
I've recently purchased a "stubby" accelerometer from a pretty well known supplier. I call it " stubby" because its low profile. I've noticed that the magnet is recessed @ .0156". This is a non-removeable magnet. My personal feeling is that the accelerometer base should be perfectly flat. Will the fact that the magnet is recessed affect the performance of the accelerometer, or does it matter. I paid @ $450.00 for this and am considering contacting the vendor to have it fixed. I've tested it with my hand held shaker and it seems to work well. I just feel that with the reccess there is to much room for trash to build up on it causing a dampening effect. It already has a slight build up of magnetic particles and being recessed it is near impossible to clean off.
Please advise.
micjk
Please advise.
micjk
RE: Que concerning accelerometer
Cheers
Greg Locock
thanks for the input. I've contacted the vendor and am waiting on a reply.correct, I don't feel as though the magnet should be recessed. all of my other mag based accel's are perfectly flat allowing for full contact over the entire base surface. Being recessed to me acts like a "circular" two pole accel which has a lower frequency responce than a flat rare earth mag ( if that makes any sense).
again
thanks for the response
