meshing: correct use of curvature control over a swept path
This may seem like a trivial problem but I cannot solve it on my own. I have created a part by extrusion and then by performing a sweep cut along a plane. The part in my model is actually a rigid body so I'm not overly concerned with mesh quality. However I have a small fillet radius which is important. To capture this geometric feature I need a high enough mesh density in the region to capture the circular nature of it (i.e. need up to say 8 seeds say to mesh the fillet properly). So I've been using the curvature control feature with some success when I'm seeding. The problem is that it seeds the outer dimensions fine but not the inner ones (I've added a picture to help you visualise). In the image you can see that the outer most area meshed properly but when you move along the direction of the sweep path the seeding goes from 8 to 2. Does anybody know a simple way to solve this? FYI I've included an image of the full part so you can see the nature of it.
RE: meshing: correct use of curvature control over a swept path
