NX7.5 Assembly loading problems
Y'alright.
When I start an assembly and load a prt file into it it always comes out bigger than it should. In modeling it's 500mm, in assemblies it's ~550mm. Any idea why it's doing this? Or if there's a way to scale models that'd be good.
Also while I'm at it, how do you make the oversized buttons along the top normal?
Cheers!
Cheers!
RE: NX7.5 Assembly loading problems
What exactly do you mean by the "oversized buttons"? Are you talking about toolbar icons with names under them? If so, try changing your Role (Resource Bar tab) to something other than one of the 'Essential' Roles.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Using the ruler tool, I've checked and double checked. It's stretching in the X and Y planes, not the Z one though... Goes from 20.925 to 25.91 and 50 to 55.01
John R. Baker, P.E.
Industry Sector
Cypress, CA
John R. Baker, P.E.
Industry Sector
Cypress, CA
www.nxjournaling.com
John R. Baker, P.E.
Industry Sector
Cypress, CA
Are you using promotions, wave links, or any type of interpart modeling?
John R. Baker, P.E.
Industry Sector
Cypress, CA
