Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your site is one of the cleanest and BEST forums that I have seen. I have sent quite a few people your way. Keep up the good work!!!"
Geography
dpc (Electrical)
6 Mar 12 12:54
This seems like a simple question, but it always generates confusion - at least with me.
For a separate, stand-alone CT Metering cabinet that is remote from the main service disconnecting means, is there a requirement to run an equipment grounding conductor to the CT cabinet in addition to the neutral/ground wire coming in from the utility service transformer?  In other words, for the service entrance conductors running from the metering cabinet (outside) to the main switchboard (inside), does the NEC require that a ground wire be run in the conduit along with the three phase wires and the utility neutral?
Helpful Member!(2)  resqcapt19 (Electrical)
12 Mar 12 13:22
The code does not require an EGC for the CT cabinet, assuming that it is on the line side of the service disconnect.  The NEC permits the service grounded conductor to be used for the grounding and bonding of non-current carrying parts on the line side of the service disconnect.  250.80
dpc (Electrical)
12 Mar 12 14:53
Thanks much.  I thought it was there, but just couldn't find it.
Dave
skiier (Electrical)
20 Apr 12 15:30
If it is metal and could become live above ground than it needs to be grounded. common sense.
Look at all those metal enclosures they used for traffic light controls and power in toronto. The ones that were flush mount on the sidewalk are the biggest problem.Salt gets in and degrades the wires to the point where the enclosure gnd develops high impedance. This combined with hot wires touching the enclosure either because the wires broke down or the enclosure was full of salty water caused the flush mount enclosures to become live.
This killed 3 dogs in the last ten years in toronto.
I tend to think someone didnt gnd the enclosure and the salty water became live.
I am an electrician and it always dumbfounds me when I have to tell journey men to gnd that enclosure. The trade really has some scary workers.
Close Box
Join Eng-Tips® Today!
Join Us             Close
