NX7.5 Moving a wall with STEP
I have a situation where I have a part that needs to be modified for blow-molding. Basically, the original design didn't leave enough space between the main body and a limb, so the solution (without changing overall dimensions) is to push the wall of the main body facing the limb in by 5mm. I've indicated the change in a picture I've attached.
Right now, I'm having trouble modeling the change in CAD. My choices for software are NX7.5, Solidworks 2006 or Catia V5. I'm limited to working with a single stp file, so I can't just change the sketches. I would appreciate any suggestions on how to approach this on any of the 3 CAD software I listed.
RE: NX7.5 Moving a wall with STEP
We'd have to have the actual part file before anyone could advise you as to a possible approach.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
Or at the very least a better picture of the area in question.
www.nxjournaling.com
