ANSYS APDL problem with a spreader beam
I have made a spreader beam in ANSYS APDL.
Having problem with the bending results. Is the geometries wrong?
finish
/clear,all
/title, kvadlofteak, hkv
!    Variables                            !
g=9.81
!    Materials                            !
/PREP7
ET,1,BEAM189
ET,2,link180: CRSI (concrete reinforcing) Code Issues Links
ET,3,COMBIN14
!Bjelkene
MP,EX,1,2.1E+5
MP,PRXY,1,0.3
MP,DENS,1,7.85E-6
!    Section properties
R,1,
R,2,10000,,1
R,3,10
!         Geometr(y/ies)
/prep7
K,1,0,0,0
K,2,8000,0,0
K,3,8000,0,-8000
K,4,0,0,-8000
K,5,4000,5657,-4000
LSTR,       1,       2
LSTR,       2,       3
LSTR,       3,       4
LSTR,       4,       1
LSTR,       1,       5
LSTR,       2,       5
LSTR,       3,       5
LSTR,       4,       5
!Guide keypoints for the beams
!K,100,1E9         ! Flat side will be rotated to point in X direction
!Wire
LATT,,2,2,,,,
ESIZE,,1
L,1,5
L,2,5
L,3,5
L,4,5
LMESH,5,8
!Frame
SECTYPE, 1, BEAM, HREC, HUP140X80, ,
SECDATA, 140, 80, 5, 5, 5, 5
LATT,1,1,1,,,,1        !MAT, REAL, TYPE, --, KB, KE, SECNUM
ESIZE,250,
L,1,2
L,2,3
L,3,4
L,4,1
LMESH,1,4
!Spring
N,1000,-100,0,0
N,1001,0,,100
N,1002,8100,,
N,1003,8000,,100
N,1004,8100,,-8000
N,1005,8000,,-8100
N,1006,0,0,-8100
N,1007,-100,,-8000
TYPE,3
REAL,3
E,1000,1
E,1001,1
E,1002,3
E,1003,3
E,1004,4
E,1005,4
E,1006,5
E,1007,5
LSEL, all
NLGEOM,ON        !Large deformations ON
!/PNUM,ELEM,0
!/REPLOT
!     DOF
/solu
DK,5,all        !Constraints keypoint 5 in all directions
*DO,x,1000,1007
D,x,all
*ENDDO
Acel,,-g,        !Global acceleration
FK,1,FY,-68670
FK,2,FY,-68670
FK,3,FY,-68670
FK,4,FY,-68670
/ESHAPE,1
EPLOT
solve
!     POSTPROCESSING
/POST1
PLDISP,1
allsel
ESEL,S,ENAME,,189    !selekterer bare BEAM189 elementene
ETABLE,Fx-i,SMISC, 1    !axial force i BEAM189, node I
ETABLE,Fx-j,SMISC,14    !axial force i BEAM189, node J
ETABLE,Mz-i,SMISC, 3    !z-bending moment i BEAM189, node I
ETABLE,Mz-j,SMISC,16    !z-bending moment i BEAM189, node J
ETABLE,SFy-i,SMISC, 6     !y-shear force i BEAM189, node I
ETABLE,SFy-j,SMISC,19    !y-shear force i BEAM189, node J
!PLLS,Fx-i,Fx-j
PLLS,Mz-i,Mz-j
RE: ANSYS APDL problem with a spreader beam
What exactly is the problem you are having with bending moment? I did not see anything wrong.
