Self supporting pole foundation
I try to design a self supporting pole foundation. The pole is 34m in length and an ultimate load at tip of 80kN,. the way i understand it, the very large moment it will create will be carried by the baseplate.. Will the pedestal be critical to that very large moment as well??? im new to this, so i need your opinion.. thank you
RE: Self supporting pole foundation
Hence once you have a proper base, the main problem will be proper transfer of the moment to the foundation (or pedestal), rather than sizing. Of course, then you will need a competent foundation to reduce tilt to the wanted standard.
h
Michael.
Timing has a lot to do with the outcome of a rain dance.
