Notches when creating an ellipsis
When cutting an ellipsis in sheet metal it is edged/notched or not a straight elliptic curve! Not only in ProE but also when the laser is making the cut! See attachment.
HELP...
I am using Pro Engineer Wildfire 1.0!
RE: Notches when creating an ellipsis
JohnDoe77,
Try seeing if one of the following config.pro settings will help
|----Option----------|----Value--------------------------------|
| edge_display_quality | (Low, Normal*, High, Very_high)              |
| save_model_display  | (Wireframe, Shading_lod *, Shading_high)|
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ Shweep
=   ProE       = SolidWorks
If the curve is calculated (i.e. curve from equation or relation) then I have seen influence similar to that with a large part accuracy.  If the default is relative .0012 then try reducing it and see if it helps.  Not sure though as I started with wildfire 3.0 and typically only see the effect of the accuracy on curves which are calculated via equations or if the ellipse is a small feature in comparison to a large part or model size.
Good luck,
- J -
