anmating Sectioning
anmating Sectioning
anmating Sectioning
Hi everybody. I have a CATProduct composed of a concrete external ring and a concrete internal ring, with a lot post-tensioned steel cables. I need to animate a section cut. I know how to animate a section with  "DMU Navigator" toolbar, but I need to cut only the outer ring but not the inner,and with the Secctioning tool,  all parts are cutted. I have tried to add a part to the CATproduct and use this part as cutting plane in "Assembly design", and then animate that section plane in DMU navigator, but the section d not update until y click update button. So i need little help.
Thanks in advance.
RE: anmating Sectioning
What are you trying to achieve? This can be done on the drawing but that is maybe not your goal
I need to create a video in which i need to see how the section cut goes from down to up cutting the outer ring but not the inner.
Can't you just cut it in half in the catpart?
Yes Azrael, but I have to make a video in which I need to see how the cut goes from down to up
What if you control the activation of the cut from a parameter on product level?
