Need to be able to use two different bolt in a hole
I need to be able to use both a 3/8" bolt and a 5/16" lag in a hole in a small U-bracket while being code compliant. We use a AISI Standard as our guide. According to it the largest whole I can use for the 5/16" lag is a 0.375" with a washer. I was wondering is there is a way around this max hole size by using a thick oversized washer. If so, what standard can I use to justify it.
RE: Need to be able to use two different bolt in a hole
Mike
The PM doesn't want to increase every thing to 3/8" because it would be wasted material and cost.
Dik
htt
