Plastic Strain Data Input
Hello All,
I am trying to input the plastic strain data into Abaqus for my aluminium material.
Now I know the Yield Stress is in MPa but what is the Plastic Strain value?
Is it the percentage of elongation?
Thanks for any help
RE: Plastic Strain Data Input
Strain has no units. It's elongation per length.
Since plastification starts above Yield stress the plastic strain at yield stress is zero
Hi Gents,
Thanks for your responses.
The strain values I have are 0.001 in/in elongation.
For example, this is the data I have:
Stress (MPa)    /    Strain (10^-3 in/in)
0                    /   0
12.0              /   0.219
26.0             /   0.417
and so on...
From graph, the yield point is around 380 MPa.
(First three points)
380.0             /   5.40
390.0            /   5.61
396.0           /   5.80
My question is what format do I input this as into Abaqus which asks for both Yield Stress (understand this field) and the 'Plastic Strain'?
Is the above (5.40) style correct or do I extrapolate this i.e. 0.00540
plastic strain = total strain - elastic strain
elastic strain = stress / youngsmodulus
you should have something like
*ELASTIC, TYPE = ISOTROPIC
(380e+06/5.4e-03), poissons ratio,
*PLASTIC
380.0e+06, 0.0
390.0e+06, (5.61-5.40)e-03
396.0e+06, (5.80-5.40)e-03
etc....
Both stress and strain need to be input in consistent units, so if your value of measured strain is 5.4e-03 at a measured stress of 380MPa, that's how Abaqus wants it.
For which aluminum alloy??
You might need to consider if you need to use engineering or true values and what values do you have in the table, from memory I think that ABAQUS expects true values.
