Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I think the forum is a great idea, especially for those of us in consulting engineering. Keep up the good work!..."
Geography
ANSYS: Writing large string/values arrays into a txt file using VWRITE
jgrzmmm (Mechanical)
5 Mar 12 15:47
Here's the short summary. I have two arrays:
- String array:
*DIM,header_names,STRING,128,50
header_names (1,1)='name_longer_than_8_digits'
header_names (1,2)='another_name'
header_names (1,3)= 'yet_another_name'
header_names (1,50)='last_name'
- Values array:
*DIM,values, ,50,100
*DO,x,1,50
*DO,y,1,100
values(x,y)=x+y
*ENDDO
*ENDDO
The main point here is that my macro is supposed to work on more than 19 parameters (which is a limtation for VWRITE) and the number of parameters is varying depends on user input. Using of manually created series of "%G,%G,%G ..." or "%C,%C,%C ..." corresponding to the number of elements in array is what I would like to avoid.
Having the following for writing into txt file:
- String array:
*CFOPEN,results,txt
*VWRITE,header_names(1,1)
%C,
*CFCLOS
results in writing the headers as a column instead of row.
- Values array
*CFOPEN,results,txt,,append
*VWRITE, values(1,1)
(2x,f18.6,$,',')
*VWRITE,
(1x)
*CFCLOS
Values are written properly, only one line, but horizontally, so that's what I want to achieve. How can this be done for headers, should I define the string array differently, or use different Fortran/C operators ?
Thank you,
Close Box
Join Eng-Tips® Today!
Join Us             Close
