Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Really appreciate your site. Really good site for learning what others do when they run into problems. You guy's are great!!!..."
Geography
MadMango (Mechanical)
5 Mar 12 15:39
Hey all,
I've been on a hunt for this part for the past several work days.  For the life of me I can't recall what this is called in order to make a useful search.  When I worked in the transportation industry, there were these flanged tubes that would be inserted in vehicle doorways to prevent wear on cables (now they might use springs).  The flange had 2-3 holes used for attachment to B or C pillars.  It basically serves as a grommet, but has a lose fit around whatever is being passed through it's center.  These were probably polyethylene or polypropylene, something very inexpensive.
Flange ~1.5"-3" diameter
Length ~2"-3" long
Tube~ .5"-1" diameter
If someone can rattle my brain (or provide a source), I'd be most appreciative.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
1gibson (Mechanical)
5 Mar 12 15:42
Whenever I know a part exists, but can't think of the specific name, I go to mcmaster.com. Since they sell almost everything imaginable, if it exists then that is where you can find it.
btrueblood (Mechanical)
5 Mar 12 15:47
C'mon Mad!  A picture (sketch) would be worth about a million google image hits here...;)
MintJulep (Mechanical)
5 Mar 12 16:11
Anything here like what you need?
http://www.heyco.com/index.cfm
5 Mar 12 16:18
Hard for me to find an image when I don't know what to call it.  I created a rough image of what I remember.
JStephen (Mechanical)
5 Mar 12 20:27
Try "standard cord grips" or "strain relief" at McMaster-Carr.  They don't look exactly like your picture, but seem to serve the purpose.  Also "grommet".
Compositepro (Chemical)
5 Mar 12 21:28
I would call it a flanged plastic bushing. Perhaps adding the word "protective" would differentiate it from a bearing bushing.
6 Mar 12 8:58
I've been to Grainger, McMaster, Heyco, Digikey, etc.  I'm almost ready to cut a 3/4" tube into 1" lengths and call it a day.
Helpful Member!  asimpson (Mechanical)
6 Mar 12 9:25
I dont think that is a standard part.
Could make it up from something like this.
http://www.skiffy.com/docs/menufr.cfm?taal=gb&pagina=start.cfm
6 Mar 12 14:39
Thanks for the link asimpson!  I can use Skiffy Series 312 Insulation Sleeves, that last one on the list will fit my application.
dhengr (Structural)
6 Mar 12 14:43
MadM:
Look at www.caplugs.com,, then look at their SB, UB or OCB Series bushings.  Also look at their FBH Series bolt hole plugs, they have longer bodies for a given dia., but you would have to punch the closed end out to use it the way you want.
Close Box
Join Eng-Tips® Today!
Join Us             Close
