Looking for a sample way to change features faces colors
I am looking for a sample way to change features faces colors.
For example: faces from sample hole to be blue and faces from threaded hole to be yellow.
I know that it's not possible with NX8. Is it possible with a sample vb programm ?
Didier Psaltopoulos
http://www.psi-cad.com
RE: Looking for a sample way to change features faces colors
Are you looking for a way to do it automatically? Manual is pretty easy with selection filter.
There is no feature selection filter in Edit Object Display
Which kind of selection filter do you propose ?
Didier Psaltopoulos
For now you'll have to select the faces which make up the feature, either individually or by region select.
In the next version of NX (the one after NX 8.0) there will be an explicit option which will allow you to select the feature itself and assign it a color.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
Below is a journal that changes the colours for simple hole features only.
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Features
Module HoleColours
    Sub Main()
        Dim s As Session = Session.GetSession()
        Dim ui As UI = ui.GetUI()
        Dim ufs As UFSession = UFSession.GetUFSession()
        Dim dp As Part = s.Parts.Work
        Dim expstring As String = Nothing
        Dim index2 As Integer = -1
        Dim exps() As Expression
        Dim ent() As NXObject
        Dim holewiththread As Boolean = False
        Dim holeexpstring As String = "thread"
        Dim hole As BodyFeature
        Dim faces() As Face
        Dim nFaces As Integer = 0
        Dim obj(-1) As DisplayableObject
        Dim displayModification1 As DisplayModification
        Dim featcoll As FeatureCollection = dp.Features
        For Each f As Feature In featcoll
            If f.FeatureType = "SIMPLE HOLE" Then
                ent = f.GetEntities()
                holewiththread = False
                exps = f.GetExpressions()
                For Each e As Expression In exps
                    expstring = e.Equation.ToString
                    index2 = expstring.IndexOf(holeexpstring)
                    If index2 > 0 Then
                        holewiththread = True
                    End If
                Next
                If holewiththread = True Then
                    hole = DirectCast(f, BodyFeature)
                    faces = hole.GetFaces()
                    nFaces = faces.Length
                    ReDim obj(nFaces - 1)
                    For i As Integer = 0 To nFaces - 1
                        obj(i) = faces(i)
                    Next
                    displayModification1 = s.DisplayManager.NewDisplayModification()
                    displayModification1.ApplyToAllFaces = False
                    displayModification1.NewColor = 6
                    displayModification1.Apply(obj)
                Else 'holewiththread is false
                        obj(i) = faces(i)
                    Next
                    displayModification1.NewColor = 211
                End If
            End If
        Next
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Hope this helps.
Frank Swinkels
Hi Franck
Thanks a lot.
Very good job, but I need more. Is it easy for you to differentiate sample hole and threaded hole with another color ?
Thanks in advance
Didier Psaltopoulos
Hi Franck,
I apologize. In fact It seems that you understand my request, but the programm set the same color on simple hole or threaded hole. did you check it ?
TIA
Didier Psaltopoulos
My only excuse is that I must be getting color blind.  I thought I had it correct on my small test part.  Below is the revised journal.  Thanks also goes to cowski for suggesting the correction.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module HoleColours
    Sub Main()
        Dim holeexpstring As String = "Threaded"
        Dim faces() As Face
                index2 = exps(0).Description.IndexOf(holeexpstring)
                If index2 > 0 Then
                End If
                        obj(i) = faces(i)
                    Next
                        obj(i) = faces(i)
                    Next
                End If
            End If
        Next
    End Sub
    End Function
End Module
Frank Swinkels
Hi Franck,
I found that the programm doesn't give the good result if I use NX with french menu !!!
So the workaround for me is to use NX with English Menu, But did you have any idea ?
TIA
Didier Psaltopoulos
We have two lines of code which use name checking.  These lines are:
and
Either or both could be a French equivalent which you would need to be changed as appropriate.
Frank Swinkels
I changed the following lines
        Dim holeexpstring As String = "TROU FILETE"
then
            If f.FeatureType = "PERçAGE SIMPLE" Then
But it doesn't work with NX in French
So I will open a call and let you informed
Didier Psaltopoulos
Open/create a model that has a simple hole and a threaded hole, then run the journal below. If it opens a listing window, then keep the line as
CODE
and change "TROU FILETE" in
CODE
to the same French word(s) reported after "description:" that denote the hole is threaded. You don't need the entire phrase after "description:", just the French equivalent of "thread" or "threaded" that is used by NX.
CODE
Imports System
Imports NXOpen
Imports NXOpen.UF
Module HoleColours
    Sub Main()
        Dim lw As ListingWindow = s.ListingWindow
        lw.Open()
                    lw.WriteLine("description: " & e.Description)
                Next
            End If
        Next
        lw.Close
    End Sub
    End Function
End Module
www.nxjournaling.com
Following my call to GTAC, we found the answer. So find below a working program with UGII_LANG set to English or French
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module HoleColours
    Sub Main()
        Dim faces() As Face
        Dim langUsed As String = ""
        ufs.UF.TranslateVariable("UGII_LANG", langUsed)
        If langUsed.Contains("French") Then
            holeexpstring = "Trou filet"
           End If
                If index2 > 0 Then
                End If
                        obj(i) = faces(i)
                    Next
                    displayModification1.NewColor = 78
                        obj(i) = faces(i)
                    Next
                End If
            End If
        Next
    End Sub
    End Function
End Module
Didier Psaltopoulos
