Will Nitronic 60 be ok with 17-4 or 303 galling.
I have a Nitronic 60 v thread I am making an adapter for. I want to use either 303 or 17-4. it just depends on what my machine shop has so I can get it quick. Isnt Nitronic 60 good for not galling? Will it gall when screwing together with 303 or 17-4..probably H1075?
thanks
thanks
RE: Will Nitronic 60 be ok with 17-4 or 303 galling.
17-4 and Nit 60 should be a good combination.
Plymouth Tube
Typically, the harder the material combination you use the better anti-galling properties. One of the biggest factors affecting galling is the real contact area of an interface; the harder the material combination the lower the real contact area.
metalhead
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
Take a look at pages 3&4 of this document:
http://w
Terry
