What is the difference between these?
The question is simple:
What is the difference between two cases shown on attached picture in terms of process of establishing datum axis for total runout measurement? Is there any or not really?
h ttp://file s.engineer ing.com/ge tfile.aspx ?folder=9f 7ca188-955 e-43cc-83c 1-857a3004 93c9&f ile=cont_f eature.pdf
I am not asking which of the approaches is better or is there any other option, I would just like to know if you see any difference and if yes, how this can be explained. Thanks a lot.
h
RE: What is the difference between these?
Case 1, centered to the one end diameter.
Case 2, centered between the two diameters.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
Frank
I say it depends on tools available.
Case 1: You have to grab BOTH end diameters with ONE chuck or collet, which may create some trouble.
If you agree to use V-blocks, then probably no difference. (Or difference between two short blocks and one really long one)
I am interested whether both dimensioning schemes result in the same definition of geometrical relationship between datum features or not. As for now I see Frank has voted they are the same. Any other votes?
No, relations between datum features are not the same.
In case 1 both features should lay within the same envelope.
In case 2 no relation between [A] and [B] is implied on the drawing
Again, I haven't given this a lot of deep thought but it seems like that may create different inspection scenarios and thus potentially different results.
Powerhound, GDTP T-0419
Engineering Technician
Inventor 2010
Mastercam X5
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
This will open up another can of worms or two. But I think you already know that ;^).
In Case #1, I don't remember if the presence or absence of extension lines makes any difference to which of the OD's are included in the continuous feature. If both are included, then the datum axis would be established using the minimum circumscribed cylinder of the two OD's.
In Case #2, the datum axis would be established using simulators shrinking down on both A and B. But Y14.5-2009 is not completely clear on the details of exactly how the simulators would shrink down. Some say that the axis would be established using the minimum circumscribed cylinder of the two OD's, identical to the CF case. This would allow the possibility of an unstable axis, if A and B were different as-produced sizes. Others say that the A and B simulators would keep shrinking down independently, until a stable datum axis was established.
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
For case #2, what if for as produced part, the offset of datum feature's axes was 1mm. How the datum feature simulators A and B would then look like?
Good point, You are right, I forgot about that!
Pmarc,
Sorry, I think CH is right, meaning we would need more info.
Frank
The axis is created by both end diameters together.
Dave D.
www.qmsi.ca
Of course you would need more info because case #2 is incomplete by intent. I did it hoping someone will answer like CH and you, so my apologies for setting this small trap.
But what is the most important for me, your and CH's responses just proved that showing datum features coaxial on a print does not mean their datum feature simulators are automatically considered coaxial too. If there is no locational relationship defined between datum features, you are not able to tell how the simulators look like - what is their size, mutual orientation and location. Look again to your 100+ thread for analogy.
I just wish I was finally able to convince Evan, J-P and Dean on this. Yeah, I realize they will probably be citing p. 4.5.2 to reinforce their point of view, but I can use p. 4.9 to reinforce mine.
I really like the fact that we get to see many points of view here. This may take forever if you had to think it through just by yourself.
You, obviously, believe this is analogous to my case, this one being coequal and the other primary-secondary, let me ponder that.
I do appreciate your not just writing me off.
Thank you,
Frank
I agree with all the responses that have been posted... I don't agree that section 4.9 tells us that the case 2 datum feature simulators are not required to be coaxial without a coaxiality tolerance applied to datum features A & B. Thank you for getting me to read section 4.9 one more time... Now I don't like it too much
I much prefer that establishing a datum be a process that is separate and independent of any tolerance evaluation of the datum features. I don't like the fact that portions of chapter 4 now tend to link the two processes.
Within reason, no matter how imperfect a set of datum features are, one should still be able to establish a datum reference frame. There should be no linking of tolerance evaluation and datum reference frame establishment processes.
My vote is that section 4.5.2 clearly tells us that the case 2 datum feature simulators for A and B are related in a "perfectly" coaxial way.
As Frank pointed out, a coaxiality control needs to be added to case 2 anyway... When this addition is made, absolutely no change should be made in the process or simulators for establishing A-B for case 2.
The confusion that Evan points out regarding potential simulator behavior differences between cases 1 and 2 is unfortunate, but real, with Y14.5 as it is now. It is currently a point of discussion within both Y14.5.1 and Y14.5 committees. I don't think those issues affect the argument you are making here, or my response to it.
Dean
www.d3w-engineering.com
Sorry but this still does not convince me. In addition to my discussion with Jim Meadows, I also spoke with Alex Krulikowski on Frank's thread (or actually on my second sketch that I created in that thread) and he also supported my standpoint. I am not saying that based on this I am 100% right, but at least I have a right to think that your interpretation is also doubtful.
Drstrole
GDTP - Senior Level
Isn't 4.5.2 in Y14.5-2009 pretty clearly stated? Where do you see the weakness in its wording?
Dean
In the other thread you said:
This descripition perfectly matches to the part shown in my second sketch in Frank's thread:
http://fi
and is absolutely correct under one fundamental condition which is the key here - the distance between datum feature simulators A & B is defined by basic zero dimension
This is actually how I understand 4.5.2. You know I have no authority to go into semantics here, but for me the word "shall" means "must". So there must be something that defines this basic relationship (by use of a method listed in para. 4.9), otherwise it does not exist. If the relationship was implied, the very first sentence of 4.5.2 would be something like: "Datum feature simulators have the following requirements" and not "shall have".
That is why I keep saying the first two cases in the link above are incomplete. That is why I keep saying case #2 from original sketch in this thread is incomplete too. They all do not meet requirements of 4.5.2 and 4.9, so the simulators B can be located anywhere relative to datum axes A and it is not possible to calculate their boundaries wrt A in any manner. It is not even possible to build a physical datum feature simulator B properly because you do not have product positional tolerance between features A & B based on which you would calculate 10% positional tolerance between simulators A & B in the fixture.
So I absolutely agree with your statement from the other thread that confusion comes from the fact that we have different interpretation of how datum feature simulators work. I am just afraid that we will not find an agreement on this because the standard is not precise enough to indicate which of us is right.
There is a Tec-Ease tip showing something similar to our situation here. Notice this one extremely important detail which does the difference - it is a position callout applied to a slot width defining basic location between datum features A & B and in consequence between their datum features simulators and making the Tec Ease's example similar to my case #3. Without this callout, you would not even need basic 14 dimension, so you would not know the basic distance between simulators A and B, so you would not know how a datum reference frame for position tolerance of small hole looks like.
http://tec-ease.com/gdt-tips-view.php?q=104
Your last posted examples do not contain the original condition? Have we moved on and I just did not catch it?
I am sorry for my confusion :)
Frank
There is no reason that a basic dimension could be considered to exist in the absence of a tolerance specification. I can't see how you can possibly read 4.5.2 in the way that you're describing. Deleting "shall" has no effect upon the requirements in this case, as far as I can manage to comprehend (then again, I am in China at the moment, so maybe I'm reading things upside down
Do others see pmarc's point? I may be missing something.
Dean
You are right, it does not contain. It is a second sketch from your 100+ thread posted by me on 6 Feb 12 6:25 and a modification of my first one.
The thing is that Dean, Evan, J-P clearly agreed that for all 3 cases there was no difference on how relationship between datum feature simulators A and B look like. I have been saying it is not the case and since I have seen this one as an analogy to the original, I am pretty sure that if we find an agreement on this, we will also find it on the original. Unfortunately it seems we are far far away from a consensus.
Peter Truitt
Minnesota
Let's leave it, okay? Actually I really got tired fighting this endless battle. You have your interpretation, I have mine. We can even do voting, if you like - and probably most of the folks will agree with you. But this will not change my point of view in any way. Sorry.
I do not expect to change your mind, either, I just want to post my responce to your OP.
You really pushed me into many other areas I have been thinking about for a while. First I want to restate my belief that the ASME standard is a good work, I spend so much time here tearing it down that I suspect people might wonder. I doubt I could do any better, but, it is clearly not perfect.
Your objections to my example seem to be based on the concept of how do you gage it. "What is my tolerance to make a gage for it?"
I have been suspecting that the discussion of the ASME standard has become too reliant on gaging to express principles. We all know parts are often not checked that way and some have even stated, here, that the use of gages is declining. Small machine shops, like mine, rarely rely on gaging and the idea that you have to gage to check part tolerances does not come from the text of the standard, people only infer this from the "pictures in the book".
No one can be expected to stop production until they have a gage to check a part. It is ridiculous to say that all parts must be gaged . Gages do have their beneficial qualities like they actually check all points at once so it is definitely a useful tool to have in your box, but, it ain't the only game in town, nor should it be. Most companies, just by judging by the voting of their dollars, don't seem to be willing to invest them there.
I also think the over reliance on gaging in the standard starts to make it irrelevant to the majority of the people who actually use it, while, it certainly makes it easier for those who want to teach it. The ISO must feel that way, too, as they seem to be heading down the path of making it more relevant to CMM measurement. This is also almost certainly why the ASME is interested in the mathematical definition of the standard so it is relevant outside the gaging world.
The standard, as I was taught, basically has always thrown away the tolerance you are looking for. How perfect is a flat surface plate, how coaxial are the 2 "A-B" chucks, what is the tolerance of a basic dimension on a gage? How perfectly perpendicular are the three mutually perpendicular planes of measurement? The answers have always been something like: "we do the best we can do to simulate this perfection, do we achieve it, no? Do you achieve it, no? Is yours better that mine, maybe? The concept of perfection is implied all over the standard.
Your OP example relies on our ability to establish the primary datum, mine is an establishment of a secondary datum. To me there is a difference. The primary datum establishes the orientation of the axes of measurement of the part to the whole world. The secondary and tertiary datums refine this, but, do not stop us from getting started.
I can find the axis of my shaft. Yours we can put in chucks/collets no matter how eccentric they are. Do I know how perfectly coaxial those chucks/collets will be, no but, we treat them as perfect. I am just not sure both of your examples parts are "identical". I did not say, either of the examples can't be done.
When those of us who do not use gages check our parts we check them to the best of our ability: establish the center of the shaft, roll the keyway to center on to center as perfect as we can, how perfect is it? There is the tolerance you are looking for. We know the keyway is to be located on zero, the standard supports it in the shown examples, if not directly in the text. The fact you don't have a tolerance to build your gage has never been part of this standard, you would have to build it the best you can like all the other measurements made to the standard.
When Mr. "doesn't recommend bothering to tolerance the orientation of short secondary datum pilot diameters" builds his gage it doesn't bother him either it has to be perfect, how perfect? It was not an issue to him, either. Do you object to his use too? I do feel it is very bad practice for him to teach this and I really did not recommend using the method I discussed either. I just said it was not illegal.
My point is your issue is really an ASME "rules of the game" issue not my "rules of the game" issue. The issue of perfection permeates the ASME standard to say it can't be done is arguing with them not me. Remember, I am an Independency supporter for just this reason. Zero position tolerances at MMC, why are they not used more often and resisted buy the shop, in horror? Why do they ignore the envelope principle in the shop making ASME's insistence on it a paradox for real day to day engineers (as opposed to people who teach)? The ISO do not really by it completely, either, they allow it to be used because the biggest gorilla in the room insists on clinging to it.
In summary, 14.5 is not a gaging standard and it makes no provision for it, which is why you have a standard specifically for that. The reliance of the standard on the concept of perfection does threaten to make it irrelevant but those are their rules of the game not mine. You can't let some play the game one way and not let all do it and be taken serious with me. The part you show is not the same condition as mine and yet it to could be checked in theory, I just don't know if it the same (the actual question). Isn't the fact that they had to add a statement like 4.5.2 to the 2009 standard, proof enough that they had to finally admit what was obvious to some of us long ago, already?
Frank
That being said, if the two datum features in #2 are produced initially as a single feature before the center portion is relieved, then you would have the same result as #1.
Jim Sykes, P.Eng, GDTP-S
Profile Services www.profileservices.ca
TecEase, Inc. www.tec-ease.com
I think you've finally convinced me that you are right on this one.
I looked up the text of Section 1.4 (k) in the Fundamental Rules. I had not done this before today, despite the fact that you referred to it in the other thread. I thought I remembered what it said, but it looks I did not.
Here is the text, for any others like myself who did not bother to actually look it up:
"A zero basic dimension applies where axes, planes or surfaces that are shown congruent on a drawing and geometric controls establish the relationship between the features."
I did not realize that this section explicitly states that a geometric control was required in order for the zero basic dimension to apply. 1.4 (k) actually makes a more compelling case than 4.9 - I wish that you had mentioned it again in this thread to hammer it through our thick skulls. We (at least Dean and I) fixated on 4.5.2.
In your Case #2, the axes of A and B are shown congruent but do not have geometric controls establishing the relationship between them. So by 1.4 (k), the zero basic dimension does not apply. Even though 4.5.2 requires the simulators to have basic location relative to each other, the basic location is not defined. I see your logic now, I apologize for not following it all the way through earlier.
It would appear that 4.5.2 and 1.4 (k) conflict with each other or are unclear at best.
Evan Janeshewski
www.axymetrix.ca
Frank
Let do it:
Will this new development of this thread "What is the difference between these?" will affect somehow the outcome for the "back-door location" thread "Spinoff2: Using orientation to control position"
(datum feature simulators as a decision turning point)
Frank
1. For the CF version the features must be treated as a single feature and fit within "a" perfect envelope at MMC. This the requirement would dictate a single datum feature simulator. The features couldn't be offset by 1mm and meet the limits of size (0.4mm in this case).
2. The A-B version would require 2 coaxial (4.12.2 fig 4-25 indicates A-B are coaxial) datum feature simulators that would allow the axis to be offset 1 mm. This would set up an angle difference between the datum feature simulators and the cylinder with the runout control . The distance between the features would impact that angle.
"4.12.2 Figures 4-24 and 4-25 are examples of a single datum
axis established from the axes of the datum feature simulators
that constrain the two coaxial diameters simultaneously."
3. Additionally the depending on the length of the part would potentially incur more cost for a long enough simulator.
I would conclude the 2 versions could yield different inspection results and inspection cost could be a factor.
Note:
ASME Y14.100
Shall is mandatory.
Will is a declaration of purpose.
Should or may are non -mandatory
I think that the back-door location effect would still exist, however. If the Position tolerance on the secondary datum feature was large and the Parallelism tolerances on the slot surfaces were small, then there would be back-door location refinement.
Does that make sense?
Evan Janeshewski
www.axymetrix.ca
As Evan said, in the first case with CF, one simulator would close in on the two features. The result could be that the part could rock due to different size features.
In the second case, in my opinion, two coaxial simulators close in on the features. This will make for a more stable set up and probably reflect how the part functions.
I have uploaded an edited video from our Premium Site. The part is the Output Shaft for the Air Clutch/Brake I manufacture under the name of Inter-Mec. The shaft rides in two bearings. Together these bearings establish an axis of rotation. I want it inspected the same way it functions. The last part of the video shows how John Rivers uses a 4 jaw chuck and indicator to align the part to the axis of the lathe using the two datum features.
This is what I always thought a A-B datum feature reference meant. The Y14.5 committee isn't so convinced and will continue to debate this for a while I am certain. So, to clarify, I probably should add a note which is always an option. At this point my supplier has tribal knowledge and knows what to do.
I think you are the guy I am always picking on! Nothing personal, I love most of your work, but I think you are the guy I was refering above, I notice I can no long find the example I thought I saw on your site, either, so it is either pussy foot around the issue or come right out and say it. Welcome here, by the way!
pmarc, I hope your last name is not "Foster".
Frank
Yes, PPAP?
What is the delta modifier, by the way?
It has been my impression from reading the standards, and the way I was first taught it, a philosophy of it being the job of a drawing to define the final acceptable part requirements, not to determine inspection methods and processes? And if the part is really not rigid (as in the case of sheet metal) why is it not their common sense to say well he can bend it there at final assembly. "Common sense" is a popular word in the political world, because it is hard to argue against. Generally it seems to be more of a "think like I do" kind of thing than a real arbitrary measure, Just like "standard" to some is more "done my way" than the way the rest of the world does it. Maybe I am falling into that same trap.
I see datums applied to parts without any additional definition all the time. From my experience all people need is another excuse not to use GD&T.
You, your self, find it necessary to remind people of the envelope principle and the simultaneous requirement; it is mainly because these fundamental principles are ignored in the shop not because people forget. Using a standard with rules that are not followed ends up not being a very useful tool kit at all. If people like yourself will not follow the rules why would anyone else?
Frank
PS I was not aware there was still an issue with A-B datum systems?
What if Parallelism applied the way Frank described was considered the geometric tolerance that establishes a relationship among the features? If the zero basic is present then the Parallelism does have this effect, since the simulator for datum feature B is then located wrt the simulator for datum feature A (again, not that I would rely on the location control provided by the Parallelism - It would be better just to be more clear and use a Position for this case). Of course this is a bit of a "Chicken and egg" assertion, since the Parallelism only provides the location control if the zero basic is present for the B simulator, and the zero basic is present per 1.4(k) only if the Parallelism provides this control... Fun
I think the orientation refinement that Evan speaks of above could take over location control if the Position tolerance is large enough. I also think that it could be argued that the Parallelism itself meets the requirement of a geometric tolerance that establishes a relationship...
Either way, an interesting topic to discuss. This has made me examine 4.5.2, 4.9, and now 1.4(k) more closely. I think the location controlling effect of the Parallelism applied in the specific way that Frank described still should be considered to be true, even though I would never recommend relying on this effect.
Dean
I must admit that I tuned out of this discussion for a little while, but the specific point about 1.4(k) vs. 4.5.2 doesn't seem blatantly problematic. (Clarification in the next version of the standard would be good, of course.)
Here's what 1.4(k) says: "A zero basic dimension applies where axes, center planes, or surfaces are shown coincident on a drawing, and geometric tolerances establish the relationship among the features."
I think the key is that the last part says "...establish the relationship..." not "...establish any relationship..."
So to me having a parallelism callout on there doesn't automatically mean that the location is a basic dim of zero -- because "the relationship" is purely orientation.
However, 4.5.2(c) does say that the datum feature simulators must be basically located, and this is where the parallelism becomes a "back-door" location control. But it's because of 4.5.2(c), not 1.4(k).
John-Paul Belanger
Geometric Learning Systems
http://www.gdtseminars.com
Please give me your impression on this statement:
I thought there was some agreement in the past that things are not retroactive? Say a FOS in 82 it does not say "directly opposed surfaces", just "plane parallel surfaces". My take in our discussion here was that the newer tighter definition would not be applicable if it did not also reference a newer standard, did I just want to believe that so hard I made it true in my mind, guys? Does anyone have a relevant experience in this area?
Frank
Newer versions of ASME standards do not automatically supersede earlier versions.
