No result is found NX
Hi
I am simulating a honey comb panel of PP, so i divided the panel in little pieces for meshing. Each mesh has it own material in material table because i want to compare my measuraments (77points hamer excitation) with the simulation and i want that some parameters change in order to get close to the eigenfrequency. But now i'm still in a beginning phase. The core and skins are anisotropic. It boundary conditions are free. When i simulate, i get no results. There is a f06 file, but i don't get what the problem is...F06 is in attachement.
Thanks in advance
Thanks in advance
RE: No result is found NX
Your material definition table 78 is not correct, the error message in the *.F06 tell you:
*** USER WARNING MESSAGE 6234 (MAT)
G13, G23 AND/OR G33 ARE NONZERO ON MAT2 ENTRY ID= 78 WHICH IS REFERENCED IN THE MID3 FIELD OF A PSHELL ENTRY.
THEY WILL BE IGNORED, SHEAR FLEXIBILITY IS SET TO ZERO.
*** USER FATAL MESSAGE 4291 (EQD4D)
FOR ELEMENT WITH ID = 1
THE MATERIAL ROUTINE -MAT- RETURNS A 2X2 J-MATRIX FOR MATERIAL ID = 78 WHICH IS SINGULAR.
Revise your material definition.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
