NX7.5 Step files
NX7.5 Step files
When importing a stp. file from a online catalouge or supplier the object comes in with approx. 4000 bodies.
what are the best settings to bring this in as maybe 1 - 10 bodies MAX.
this seems to be slowing the system down alot!
Please Help
Please Help
RE: NX7.5 Step files
If so, try the Sew surfaces automatically option.
www.nxjournaling.com
Tried both with that on and off and same outcome either way?
How many solid bodies are you expecting to be in this file? The first post mentions 1 - 10 bodies, are you importing a single part file or an assembly?
There is an assembly, by the looks of the assembly there would be about 10-15 components. It is a fan housing with the components inside. However i am not wanting to do anything with the assembly, its just for visual aid. So the housing would be sufficient. I can delete all the bodies internal of the housing but still would be left with alot of sheet bodies for the housing.
In the inport option, you can select "flatten assembly".
Meaning that all bodies, including the "component bodies", are in one partfile (the ons you import to).
The assembly structure is lost.
Older budweiser
Do you have any other CAD packages at your disposal?
