Minimum distance between two butt joints plate 2.5" thick for steel st
Please can anyone advise on below
1, Minimum distance between two butt joints plate 2.5" thick for steel structure according AWS D1.1
2, Will there be a requirement to PWHT these welds if the HAZ material grade ASTM A514
RE: Minimum distance between two butt joints plate 2.5" thick for steel st
2. PWHT for AWS D1.1 is at the discretion of the engineer. AWS does not specify it. Manufacturers of A514 do not recommend PWHT though.
