Anchor Blocks
Anchor Blocks
Anchor Blocks
Saudi Aramco, long known for what many have thought to be an excessive demand for pipeline anchor blocks in that 1.) they require anchor blocks on pipelines entering/exiting pump stations, even if they were not required (which may still be the case), and 2.) for specifying conditions that make such anchor blocks extremely oversized as well.  I just found an article appearing in their Q2 edition of 2011 Journal of Technology looking at ways to reduce the size.
I'd like to eliminate these anchor blocks entirely (when not needed), but this is certainly a "monumental" step in the right direction.
See attached JOT article.
From "BigInch's Extremely simple theory of everything."
RE: Anchor Blocks
But... but... but... that's the way we've ALWAYS done it!  You can't change "always"!
- Steve Perry
http://www.linkedin.com/in/stevenhperry
This post is designed to provide accurate and authoritative information in regard to the subject matter covered.  It is offered with the understanding that the author is not engaged in rendering engineering or other professional service.  If you need help, get help, and PAY FOR IT.
RE: Anchor Blocks
I think they just must have finally gotten worn down by the constant flack.
RE: Anchor Blocks
I'm guessing that baby weighs in at 400 tons, maybe they are running out of concrete
RE: Anchor Blocks
Or may be they didn't have a portable batch plant
