Create Linked Exterior using NX open
I am trying to create a linked exterior using VB.NET code.Even though i provide my program with a selected body and a face to create the linked exterior , the selected face is not getting attached to the body using code.
Any reason why the face is not getting attached ?
PFB the code below
Private Sub Button6_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button6.Click
        'Dim dPart As Part = s.Parts.WorkComponent
        Dim bodies(0) As Body
        bodies(0) = sBody
        Dim comps(bodies.Length - 1) As Assemblies.Component
        Dim xforms(bodies.Length - 1) As NXOpen.Tag
        Dim body_tags(bodies.Length - 1) As NXOpen.Tag
        Dim proto As NXObject
        'MsgBox("running")
        Try
            For ii As Integer = 0 To bodies.Length - 1
                If bodies(ii).IsOccurrence() Then
                    comps(ii) = bodies(ii).OwningComponent
                    proto = bodies(ii).Prototype
                    body_tags(ii) = proto.Tag
                    ufs.So.CreateXformAssyCtxt(comps(ii).Tag, _
                        comps(ii).Tag, NXOpen.Tag.Null, xforms(ii))
                    MsgBox("running1")
                Else
                    comps(ii) = Nothing
                    body_tags(ii) = bodies(ii).Tag
                    xforms(ii) = NXOpen.Tag.Null
                    MsgBox("running2")
                End If
            Next
            'MsgBox("running")
            Dim directions(,) As Double = _
                {{1, 0, 0}}
            Dim n_faces As Integer = 1
            Dim faces(0) As Tag
            faces(0) = sTag
            Dim comp_index() As Integer = Nothing
            'comp_index(comp_index.Length - 1) = 1
            'MsgBox("running")
            'ufs.Modl.IdentifyExteriorUsingHl(bodies.Length, body_tags, _
            '    xforms, 6, directions, _
            '    0.0254, _
            '    UFConstants.UF_LINKED_HL_RES_COARSE, n_faces, faces, comp_index)
            'MsgBox("running")
            'body_tags(0) = bodyTag
            Dim extData As UFModl.LinkedExt
            With extData
                .at_timestamp = False
                .bodies = body_tags
                .delete_openings = True
                .faces = faces
                .group_results = UFConstants.UF_LINKED_EXT_GROUP_NONE
                .mass_props = True
                .num_bodies = bodies.Length
                .num_faces = faces.Length
                .xform_index = comp_index
                .xforms = xforms
            End With
            'MsgBox("running")
            Dim extFeat As NXOpen.Tag = Nothing
            Dim mark As Session.UndoMarkId = s.SetUndoMark( _
                Session.MarkVisibility.Visible, "Create Linked Exterior")
            ufs.Modl.CreateLinkedExterior(extData, extFeat)
            'MsgBox("running")
            Dim n_groups As Integer
            Dim groups() As NXOpen.Tag = Nothing
            Dim n_subfeats As Integer
            Dim subfeats() As NXOpen.Tag = Nothing
            Dim mass_props(46) As Double
            ufs.Modl.AskLinkedExterior(extFeat, extData, n_groups, groups, _
                n_subfeats, subfeats, mass_props)
            Dim bList As ArrayList = New ArrayList
            Dim bTag As NXOpen.Tag
            For ii As Integer = 0 To n_subfeats - 1
                ufs.Modl.AskFeatBody(subfeats(ii), bTag)
                bList.Add(bTag)
            Next
            MsgBox("done")
            'Dim bTags() As NXOpen.Tag = bList.ToArray(GetType(NXOpen.Tag))
            'ufs.Modl.DeleteBodyParms(bTags)
            'ufs.Ps.ExportData(bTags, "C:\temp\export_test.x_t")
        Catch ex As Exception
            MsgBox(ex.StackTrace + Chr(13) + Chr(13) + Chr(13) + ex.Message)
        End Try
    End Sub
