Microstation j7 - shape files
I read some where that .shp(??) files can be loaded into MS.
How?? Does the file need to be georeferenced or does it load in at the proper location?
Thanks -
Thanks -
RE: Microstation j7 - shape files
http://www.guthcad.com.au/arcv2cad.htm
This file will do 10 translations of any size free, and is then limited to a small file size (<32k) until you register it (I think that it's about $100).
I've used this several times and it works pretty seamlessly.
Good luck,
Rob
So once it is in dxf, the file will load into MS at the proper geo-location without additional steps??
Big time thanks - J
Hope this helps,
Rob
Do you know how to load them in to ArcExplorer 3.x?
Good luck
basila@msdinc.com
