NX4 Maintenance Release 4.0.4.2 Will Not Load
I have successfully loaded NX4 (64 bit) on Windows 7 Pro 64 bit).
I have downloaded MR 4.0.4.2 (64 bit) from Siemens web site.
When I execute the ugs_update.bat the dos window reads: This script will install NX 4.0.4.2 Maintenance Release files in:
"C:\Program Files\UGS\NX\4.0"
Press any key to continue...
This looks correct however when I run it, I receive many (can't create)warnings. Please see attached jpeg.
Mark -
Mark -
RE: NX4 Maintenance Release 4.0.4.2 Will Not Load
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Mark -
Are you sure that you're installing a 64-bit update onto a 64-bit version of NX 4.0? You may wish to delete the upgrade kit you downloaded and start over.
John R. Baker, P.E.
Industry Sector
Cypress, CA
