coating selection
coating selection
Dear All,
I need some help about how to choose appropriate coating for a particular application. I think I must be considered two parameters, corrosion and wear condition. actually for wear resistance i have no idea how to correlate wear condition with wear properties of coating. For example in particular environment how to choose a coating from data such as wear data test or hardness of coating. i would be grateful if someone could help me or introduce me some reference.
RE: coating selection
Dik
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
"There are probaably a lot more concerns at your plant about the chemistry of the water than worrying about the pump impeller, so rather than change the chemistry of the water, use a good, not cheap, coating on the impeller and not worry about it.
You should also consider that impellers do see cavitation, abrasion from solid entrainment, galvanic corrosion and other forces. So when you choose a coating look at all of these factors. I have been in this field for over thirty years and have repaired and coated pumps in every situation you can imagine and done it all over the world. This is your most practical solution.
Yes I do happen to manufacture coatings for pumps. We would llike to think that ours are the most advanced coatings on the market and priced fairly, but there are others available also. If you would like some information on my products, Arcor Epoxy Coatings and some educational material on how to choose a coating, please let me know."
From this gentleman:
http://w
Steve Jones
thanks a lot, actually i look for epoxy coating but i don't live in America and im afraid you don't have any distributor in other country.however i would appreciate to let me have some educational material on how to choose a coating
"Sharing knowledge is the way to immortality"
His Holiness the Dalai Lama.
http://waterhammer.hopout.com.au/
