Pilot of Pressure Reducing Valves Vs direct acting pressure reducing
Hi Our Experts,
I have pilot operated pressure reducing valves 6" , brand is
,pilot model 1340 , pilot spring range 20-80 psi is damaged,
My question is : can I use another manufacturer for directing acting pressure reducing valve size 1/2"  instead of the pilot.
pilot port size is 1/2".
In another way can we replace damaged pilot (2 way) for PRV to another manufacturer for direct acting pressure reducing valves? also another concept.
The problem I face that the price of pilot as spare part is higher than direct acting PRV.
NOTE. I will try to find same spring stiffness for to keep 20-80 psi.
Also you can find the attached files.
Baram
