Generator High Resistance Grounding Connection
This is for an offshore installation, IEC world.
There are 4 gas turbine generators (4x33%) connected to a 6.6kV switchboard.
The generators are high resistance grounded (20A per generator). It is a 3 Ph, 3 wire system
Now regarding the connection of the resistors to the installation structure, client wants that there shall be two connections from the resistor (ground side) for neutral grounding. One cable should be connected directly to the nearest structure and the other cable shall be connected to the ground bar (PE) of the 6.6kV switchboard. The PE bar is of course grounded at either end. The following clause of IEC-61892-2 is taken as reference for proposing this arrangement by client.
5.7.2 Earthing resistors shall be connected to the unit's structure or hull. In addition earthing resistors shall be connected together on the structure/hull side of the resistor, where to also the protective earthing (PE) conductor of the distribution system shall be connected.
Is it the correct interpretation of IEC? What we are having is that the generators are resistance grounded individually and also connected to a common PE bar thus forming a common grounding point for all the parallel generators.
Frankly speaking, I have not seen this kind of arrangement before.
Advise and guidance is requested.
Thanks a lot in advance.
