Allowable stress differences between product forms for the same grade
If you have a given material grade, for example 316 or 304 stainless, is it typical to expect the allowable stresses in the B&PVC to vary depending on the product form you select (bar, pipe, plate, forging)? 316 is probably a bad example because I am pretty sure the allowable stresses are the same independant of grade. However, for other materials would you expect the allowable stresses to vary depending on what grade you select? What drives these changes (grain structure, hardness, ect.)?
Thanks.
Thanks.
RE: Allowable stress differences between product forms for the same grade
What drives the changes? Uhhh, metallurgy:)
Mike
