What temp can alloys be heated to without affecting mech props?
Does anyone have guidelines for acceptable temperatures that a given alloy can be raised to and then cooled again to room temp without affecting its mechanical properties? I have a shrink fit bushing (C63000 nickle alum bronze) in a housing (AL 7050-T7451). I am curious how hot I can heat the assembly to aid in removing the bushing, but not damage the materials. I have looked at the annealing temps for the 7050. If I stay below those temps, will the material remain unchanged? I have even less info on the C63000. Any guidelines or info sources you could point me to would be appreciated.
Luke
Luke
RE: What temp can alloys be heated to without affecting mech props?
Good luck
If the bushing [or a solid bolt] is in high interference [or is otherwise "stuck" in-place] AND it is NOT destined to be salvaged, then consider step-drilling/reaming thru the center, until the interference load disappears... then pop the bushing out. NOTE: use plenty of coolant to minimize heat-build-up!
Regards, Wil Taylor
