Scada Recipe Function
Hi I am doing a project where I control a motor using siemens plc, vsd and scada wincc. I want to have 3 different sequences and using the Scada recipe function call sequence 1, sequence 2 and sequence 3 at different times etc. how can I do this using the recipe function? I have the sequences programmed into different functions on my PLC program but obviously I cannot download them together.? Can any one help. I hope this message makes sense. Thank you.
Derek
Derek
RE: Scada Recipe Function
This particular forum is targeted to users of Siemens CAD product, NX (formerly Unigraphics). While there may be someone here that can answer your quesion, you will have a better chance in either forum791: Programmable Logic Controllers (PLC) or possibly forum237: Electric motors, generators & controls engineering.
Good luck!
www.nxjournaling.com
