spotface diameter for m42 nut
hello - sorry for the lame post but i would like to know if anyone has a chart or table for spotface diameters larger then m36 - my table only goes to m36 nuts - any help would be appreciated - right now i used the same distance from the nut points on the m36 to the spotface diameter o.d. - thank you again
RE: spotface diameter for m42 nut
Well then you're doing it wrong.
You'd theoretically need the distance across the 'nut points' plus the position tolerance (and clearance of the bolt in the hole/holes if deliberately over sized).
If you have the head information for the M42 you should be able to work it out.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
hello again - i had taken all that into consideration when i came up w/ the dimension - i just did not get into the details of how i did it - thank you again -
