Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks for creating this site - I expect to be visiting it often as I continue to try to grow my bag of tricks!..."
Geography
Pressure developed in open well with explosive atmosphere.Helpful Member!
AusGasMan (Civil/Environmental)
2 Mar 12 6:39
I was recently preparing a well for a rig over. Initial gas monitoring read 0. On removal of a temporary cover plate by hot cutting.  After removal of cover plate the gas tester was inserted into an open well and recorded an explosive atmosphere. My question is a general estimate of what sort of pressure could have been generated had the atmosphere ignited when hot cutting. Type of gas is uncertain as no reading of methane or hydrogen sulphide was on the testing machine. The well head was 1 meter underground but an open pipe marker was sitting on top of the temp plate. I did consider rust inside the pipe may have depleted the oxygen to a level where a small amount of gas may have produced an explosive atmosphere. I will request a SOP for this situation and would appreciate some advise of my concerns so as not to get shafted by others. I can provide any other relevant info.
MiketheEngineer (Structural)
2 Mar 12 10:22
Really hard to say with the lack of information - but 5 psi or about 700 psf over pressure might not be uncommon!!
Helpful Member!  Compositepro (Chemical)
2 Mar 12 17:54
The maximum combustion pressure of a hydrocarbon-air mixture in a perfect fuel-air ratio is about 150 psi (or ten times initial pressure).
Close Box
Join Eng-Tips® Today!
Join Us             Close
