Sensor values for multiple points on analytical rigid
is there a way to get sensor values (COORD) for multiple points on an analytical rigid surface? When I try to create a set, i can only choose the reference point of the rigid body. And it seems like multiple reference points on analytical surfacs are not working?
The core problem is: I have two bodies, the analytical rigid and a deformable and need to know the distance of a certain node on the solid element to the surface of the analytical rigid.
Any help highly appechiated.
Kind regards,
xaero24
