save as parasolid favor
Can someone open the attached Fanuc robot saved as SW2011 and resave as a parasolid? We haven't upgraded yet still stuck on 09.
Wouldn't let me upload it all in 1 zip file so attached is zip 1.
Certified SolidWorks Associate
SW2009 X64 SP 1.0
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
RE: save as parasolid favor
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
Do you mind trying as something else? step? Different parasolid version?
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
I use to keep a spreadsheet showing the Parasolid version used in which version of UG/NX, SW and SE.
Ben Loosli
Certified SolidWorks Professional
The OP should have specified the version rather than let the group guess which version of parasolid '09 used.
Lesson learned, never assume that the group has access to your setup.
Parasolid, unlike VDAFS, STEP and IGES is version specific.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
Thanks for every ones help. If Fanuc would make it a little easier to get 3D models of their robots I wouldn't of had to ask. I went through the process on their website to be sent an iges but never received it. Found this model on grabcad.com
http://grabcad.com/library/fanuc-m-10ia-robot
Thanks again.
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
