static equivalent to a dynamic load
I need some help converting a load.  Right now I have a dynamic load.  I have mass=76.5 kg, acceleration=6g's (58.8 m/s^2) and time=0.667 s.  The load is out on a cantilever and is being subjected to an impulse (there is no impact).
The setup is similar to someone on a diving board, quickly going from standing to crouching.  There is deflection at the end of the diving board, but there is no impact.  I do not think energy method can be applied here because, height is difficult to determine.
I know the current setup holds up under the above conditions.  I want to test the setup until failure. I would like to use a pull station to isolate this part.  I should be able to do this if I can turn the result of the static test into an equivalent impulse result.
I cannot remember how to convert a static load into an equivalent impulse.  Can anyone point me in the right direction?
RE: static equivalent to a dynamic load
For a quick "back of envelope" calculation:
Dyn Amplification factor = 1 / (1-fa/Fn)
Where fa is the frequency of the equipment and Fn is the natural frequency of the cantilever beam.
from the data provided, why not F=ma ?  but i guess you'll say the acceleration isn't constant, maybe a sin (or cos ?) with 1/4 wavelength of 0.667s ??
if it is similar to a person quickly crouching ... isn't the person giving up potential energy (lowering their CG) ?  where does that energy go ?  strain energy in the diving board ??
You are correct that the center of gravity lowers, but measuring that distance is not possible.
The acceleration is not constant, but I do have the acceleration profile over time.  This is a one shot test.  The setup has to survive once to "pass"...
Does the accelerometer data (6g's) take in to account the fact that this is an impulse?
accelerometers measure acceleration ...
but you can derive impulse from acceleration ...
Suddenly applied loads (not impact from a moving object with sizeable mass) are simulated by doubling the load.  I am away from my office so I don't have my original source (Terzaghi.) This was originally based on the observation that a suddenly applied load would result in a doubling of the elastic elongation of a steel rod as compared to the same load applied under static conditions.  While not accurate for relatively high energy transfer, it works for gravity-magnitude transactions for typical members.
