Concrete Creep due to Increased Load on a 12 year old floor
If an increased load is applied to a concrete floor slab after the floor has been in use for 12 years or so, what is the creep factor that should be used to predict the additonal long term creep due to the additional load?
Can creep be essentailly ignored because the concrete is so old at the time of application of the additional load?
RE: Concrete Creep due to Increased Load on a 12 year old floor
(I don't think I've ever written a sentence like that)
There is a maturity effect that reduces the amount of creep as the time of loading is extended, but there will still be creep. According to the Australian code it would reduce by about 30-40% from loading at 7 days after about 1 year and then stay constant at that figure. But the reduction from 28 days to 1 year is only 10%.
So it depends on your starting point or starting assumption! If you are simply using code multipliers, you would not know!
Other than that JAE is correct.
If you look at your design codes creep data it should tell you.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
Later I will add zip with some Mathcad 2000 worksheets giving creep data.
