Has anyone out there heard of equip
Has anyone out there heard of equipment to orbitally laser weld stainless 316 tubing. TIG welds require high sulfur levels in the steel which screws up corrosion resistance.
Tube diameters 1/2 to 1 inch. Wall thickness 0.030 inch.
RE: Has anyone out there heard of equip
I'm not so sure that tig welding requires high sulfer levels, I think that they just require similar sulfer levels. The sulfer affects the currents in the weld pool, and if one side has more sulfer than the other, the weld penetration will favor the side with more sulfer, and may miss the joint.
