ETAP - Protection Time-Current Curves - Current offset error
When I assign a fuse or relay from the ETAP library to the one-line diagram symbol of an existing ETAP model, ETAP plots the time-current curve offset to the right by a current factor of 1.17.
When I assign the same fuse or relay from the ETAP library to the one-line diagram in a new ETAP model, ETAP correctly plots the time-current curve without the current offset.
Have any ETAP users encountered this problem, and how is it resolved ?
RE: ETAP - Protection Time-Current Curves - Current offset error
I don't know much about ETAP, but the 1.17 is suspiciously close to the actual factor of 1.15 to make me think it is probably related to this.
However the "shift factor" is set to 1.00
I have found that by deleting the fuse or relay and re-assigning the identical fuse or relay, the software plots correctly without the shift. This not a satisfactory solution.
